Dell Inspiron 15z 1570 Memory Modules Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: step 2, image 1 of 2 Dell Inspiron 15z 1570 Memory Modules Replacement, Popping up the Memory Modules: step 2, image 2 of 2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  2. Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: step 3, image 1 of 2 Dell Inspiron 15z 1570 Memory Modules Replacement, Align the Notch: step 3, image 2 of 2
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  3. Dell Inspiron 15z 1570 Memory Modules Replacement, Sliding the Memory Module: step 4, image 1 of 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Finish Line
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 67
