Dell Inspiron 17-5748 Keyboard Replacement
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: step 2, image 1 of 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: step 3, image 1 of 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: step 5, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 5, image 2 of 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: step 6, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 6, image 2 of 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: step 7, image 1 of 2 Dell Inspiron 17-5748 Keyboard Replacement: step 7, image 2 of 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Justine Vaca
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 668
