Dell Inspiron 17-5748 Speakers Replacement
  1. Dell Inspiron 17-5748 Speakers Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Speakers Replacement: step 2, image 1 of 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Speakers Replacement: step 3, image 1 of 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Speakers Replacement, Speakers: step 4, image 1 of 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: step 4, image 2 of 3 Dell Inspiron 17-5748 Speakers Replacement, Speakers: step 4, image 3 of 3
    • Remove the 4.5 mm Phillips #0 screw holding the Optical Drive in place.
    • Slide the Optical Drive out of the device.
  5. Dell Inspiron 17-5748 Speakers Replacement: step 5, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 5, image 2 of 2
    • Remove the two 4.5 mm Phillips #0 screws on the access panel door.
  6. Dell Inspiron 17-5748 Speakers Replacement: step 6, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 6, image 2 of 2
    • Using a plastic opening tool, pry open the access panel, exposing the disk drive, RAM, and wireless module.
  7. Dell Inspiron 17-5748 Speakers Replacement: step 7, image 1 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 7, image 2 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 7, image 3 of 3
    • Remove the 2.5 mm Phillips #0 screw securing the hard drive.
    • Slide the hard drive out using the pull tab.
    • Remove the hard drive from the device.
  8. Dell Inspiron 17-5748 Speakers Replacement: step 8, image 1 of 1
    • Open the laptop and locate the keyboard.
  9. Dell Inspiron 17-5748 Speakers Replacement: step 9, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 9, image 2 of 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  10. Dell Inspiron 17-5748 Speakers Replacement: step 10, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 10, image 2 of 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  11. Dell Inspiron 17-5748 Speakers Replacement: step 11, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 11, image 2 of 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
  12. Dell Inspiron 17-5748 Speakers Replacement: step 12, image 1 of 1
    • Remove the five 4.5 mm Phillips #0 screws found under the keyboard.
  13. Dell Inspiron 17-5748 Speakers Replacement: step 13, image 1 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 13, image 2 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 13, image 3 of 3
    • Do not fully remove the palm rest until the ribbon cable underneath is detached.
    • Using a plastic opening tool, separate the plastic palm rest and partially lift the palm rest from the device.
    • Remove both ends of the ribbon cable. This can be done by flipping up the black tabs securing both ends.
    • Remove the palm rest from the device.
  14. Dell Inspiron 17-5748 Speakers Replacement: step 14, image 1 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 14, image 2 of 3 Dell Inspiron 17-5748 Speakers Replacement: step 14, image 3 of 3
    • Locate the first speaker.
    • Unplug the speaker cable.
  15. Dell Inspiron 17-5748 Speakers Replacement: step 15, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 15, image 2 of 2
    • Lift the speaker from the corner.
    • Remove the speaker.
  16. Dell Inspiron 17-5748 Speakers Replacement: step 16, image 1 of 2 Dell Inspiron 17-5748 Speakers Replacement: step 16, image 2 of 2
    • Using the plastic opening tool, gently remove the second speaker.
Bradley
235 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 558
