Dell Inspiron 17-5749 Battery Replacement
  1. Dell Inspiron 17-5749 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 17-5749 Battery Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 17-5749 Battery Replacement: step 2, image 2 of 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
Christopher Tran
1,162 Reputation
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 482
