Dell Inspiron 17-7737 Battery Replacement
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: step 1, image 1 of 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: step 2, image 1 of 3 Dell Inspiron 17-7737 Battery Replacement: step 2, image 2 of 3 Dell Inspiron 17-7737 Battery Replacement: step 2, image 3 of 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: step 3, image 1 of 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 17-7737 Battery Replacement: step 4, image 2 of 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
Mark Batista
457 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 33
All Time: 266
