Dell Inspiron 17-7737 Hard Disk Drive Replacement
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 2, image 1 of 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 2, image 2 of 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 2, image 3 of 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 3, image 1 of 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 4, image 1 of 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 4, image 2 of 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: step 5, image 1 of 1
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 6, image 1 of 1
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 7, image 1 of 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 7, image 2 of 2
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 8, image 1 of 1
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: step 9, image 1 of 1
    • Using the pull tab, lift the hard drive out of the cage.
Mark Batista
457 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 263
