Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement
  1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: step 1, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: step 1, image 2 of 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 2, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 2, image 2 of 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 3, image 1 of 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 3, image 2 of 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 3, image 3 of 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 4, image 1 of 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 4, image 2 of 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: step 4, image 3 of 3
    • Carefully remove the base cover from the laptop.
Delia Padilla
564 Reputation
5 Guides authored
Gateway, Team 1-3, Class Fall 2022 Member of Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 20
All Time: 150
