Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: step 1, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: step 1, image 2 of 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 2, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 2, image 2 of 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 3, image 1 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 3, image 2 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 3, image 3 of 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 4, image 1 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 4, image 2 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 4, image 3 of 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: step 5, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: step 5, image 2 of 2
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 6, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 6, image 2 of 2
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 7, image 1 of 1
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 8, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 8, image 2 of 2
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: step 9, image 1 of 2 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: step 9, image 2 of 2
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 10, image 1 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 10, image 2 of 3 Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: step 10, image 3 of 3
    • Lift the heatsink off the motherboard.
Delia Padilla
564 Reputation
5 Guides authored
Gateway, Team 1-3, Class Fall 2022 Member of Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 92
