Introduction
A smooth touch pad with soft clicks, and is compatible with gestures.
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Detach the tab connecting the battery to the system board using your fingers or a pair of tweezers.
Peel off the adhesive tab holding the cable to the device.
Lift the latch holding down the ribbon cable connected to the touch pad.
Remove the three screws holding down the bracket on the bottom portion of the touch pad using a Phillips #0 screwdriver.
Remove the four screws holding down the bracket on the upper portion of the touch pad using a Phillips #0 screwdriver.
Remove the bracket on the bottom portion of the touchpad by carefully peeling it away, as it is held by adhesives, then set it aside.
