Dell Inspiron 1721 Display Assembly Replacement
  1. Dell Inspiron 1721 Display Assembly Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement, Battery: step 1, image 2 of 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: step 2, image 3 of 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: step 3, image 3 of 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: step 4, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: step 4, image 2 of 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 Display Assembly Replacement: step 5, image 1 of 1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 Display Assembly Replacement: step 6, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 6, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 6, image 3 of 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 Display Assembly Replacement: step 7, image 1 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 7, image 2 of 3 Dell Inspiron 1721 Display Assembly Replacement: step 7, image 3 of 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 Display Assembly Replacement: step 8, image 1 of 2 Dell Inspiron 1721 Display Assembly Replacement: step 8, image 2 of 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 11
All Time: 172
