Dell Inspiron 1721 Heat Sink Replacement
  1. Dell Inspiron 1721 Heat Sink Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1721 Heat Sink Replacement, Battery: step 1, image 2 of 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Heat Sink Replacement, Hinge Plate Cover: step 2, image 1 of 3 Dell Inspiron 1721 Heat Sink Replacement, Hinge Plate Cover: step 2, image 2 of 3 Dell Inspiron 1721 Heat Sink Replacement, Hinge Plate Cover: step 2, image 3 of 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Heat Sink Replacement, Display Assembly: step 3, image 1 of 2 Dell Inspiron 1721 Heat Sink Replacement, Display Assembly: step 3, image 2 of 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  4. Dell Inspiron 1721 Heat Sink Replacement: step 4, image 1 of 1
    • Disconnect the antenna connectors from the WLAN card.
  5. Dell Inspiron 1721 Heat Sink Replacement: step 5, image 1 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 5, image 2 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 5, image 3 of 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  6. Dell Inspiron 1721 Heat Sink Replacement: step 6, image 1 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 6, image 2 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 6, image 3 of 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  7. Dell Inspiron 1721 Heat Sink Replacement: step 7, image 1 of 2 Dell Inspiron 1721 Heat Sink Replacement: step 7, image 2 of 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  8. Dell Inspiron 1721 Heat Sink Replacement, Back Cover: step 8, image 1 of 1
    • Disconnect the touch pad connector.
  9. Dell Inspiron 1721 Heat Sink Replacement: step 9, image 1 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 9, image 2 of 3 Dell Inspiron 1721 Heat Sink Replacement: step 9, image 3 of 3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  10. Dell Inspiron 1721 Heat Sink Replacement, Heat Sink: step 10, image 1 of 3 Dell Inspiron 1721 Heat Sink Replacement, Heat Sink: step 10, image 2 of 3 Dell Inspiron 1721 Heat Sink Replacement, Heat Sink: step 10, image 3 of 3
    • Unscrew the Phillips #0 screws attaching the heat sink to the motherboard.
    • The screws attaching the heat sink to the motherboard are part of the heat sink.
    • Carefully remove the heat sink from the motherboard.
    • You may have to apply upward force while removing the heat sink from the motherboard, due to the thermal paste between it and the CPU.
Kristen Gismondi
84,850 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 176
