Dell Inspiron 1750 Hard Drive Replacement
  1. Dell Inspiron 1750 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Hard Drive Replacement: step 2, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement: step 2, image 2 of 2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Remove the two 1mm double wide Phillips #00 screws.
    • Pull the hard drive away from the laptop.
  4. Dell Inspiron 1750 Hard Drive Replacement: step 4, image 1 of 2 Dell Inspiron 1750 Hard Drive Replacement: step 4, image 2 of 2
    • Keep all screws in a safe place. You may need to use them for your new hard drive.
    • Remove the two #00 1mm screws on both sides of the hard drive.
    • Pull the hard drive cover away from the hard drive and set the cover aside.
3 other people completed this guide.
Tina Rickard
759 Reputation
5 Guides authored
Cal Poly, Team 6-3, Forte Spring 2014 Member of Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 42
All Time: 9,492
