Dell Inspiron 17R-5737 Access Panel Replacement
  1. Dell Inspiron 17R-5737 Access Panel Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Access Panel Replacement: step 2, image 1 of 2 Dell Inspiron 17R-5737 Access Panel Replacement: step 2, image 2 of 2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Access Panel Replacement: step 3, image 1 of 2 Dell Inspiron 17R-5737 Access Panel Replacement: step 3, image 2 of 2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Access Panel Replacement, Access Panel: step 4, image 1 of 1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
Mack Chabot
645 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 354
