Dell Inspiron 3148 RAM Replacement
  1. Dell Inspiron 3148 RAM Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 3148 RAM Replacement, Back Panel: step 1, image 2 of 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 RAM Replacement: step 2, image 1 of 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 3148 RAM Replacement: step 3, image 2 of 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 RAM Replacement, RAM: step 4, image 1 of 1
    • Locate the RAM chips on the motherboard.
  5. Dell Inspiron 3148 RAM Replacement: step 5, image 1 of 1
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  6. Dell Inspiron 3148 RAM Replacement: step 6, image 1 of 2 Dell Inspiron 3148 RAM Replacement: step 6, image 2 of 2
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
Christopher Gravelle
837 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 319
