Dell Inspiron 3501 Back Cover Replacement
Introduction
Go to step 1Use this guide to replace the back cover on your Dell Inspiron 3501.
Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
Use the Phillips screwdriver to loosen the two captive screws.
Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
Pry upward to release the retaining clips.
Repeat this procedure for the bottom-right corner of the back cover.
At the sides of the laptop, insert your opening pick between the cover and body.
Pry upward to release the remainder of the clips.
Grab the cover by the edge closest to you.
Lift the cover up. Swing it open so that the rear edge lifts up last.
Completely remove the cover from the laptop.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
