Dell Inspiron 3520 Screen Replacement
  1. Dell Inspiron 3520 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 3520 Screen Replacement, Battery: step 1, image 2 of 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Screen Replacement: step 2, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 2, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 2, image 3 of 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Screen Replacement, Keyboard: step 3, image 1 of 2 Dell Inspiron 3520 Screen Replacement, Keyboard: step 3, image 2 of 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Screen Replacement: step 4, image 1 of 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Screen Replacement: step 5, image 1 of 2 Dell Inspiron 3520 Screen Replacement: step 5, image 2 of 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 1 of 3 Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 2 of 3 Dell Inspiron 3520 Screen Replacement, Screen: step 6, image 3 of 3
    • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
    • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
    • Disconnect the two controlling wires with the blue pull tabs.
  7. Dell Inspiron 3520 Screen Replacement: step 7, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 7, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 7, image 3 of 3
    • Using the spudger, carefully work your way around the edge of the upper shell.
    • Lift the upper shell away from the laptop.
    • Close the laptop and remove the casing over the hinge using the spudger.
  8. Dell Inspiron 3520 Screen Replacement: step 8, image 1 of 3 Dell Inspiron 3520 Screen Replacement: step 8, image 2 of 3 Dell Inspiron 3520 Screen Replacement: step 8, image 3 of 3
    • Gently pull the cable located near the fan free from its dock.
    • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
    • The board should then pull free.
    • Take note of how the cables fit along the ridge for when it comes to reassembly.
  9. Dell Inspiron 3520 Screen Replacement: step 9, image 1 of 2 Dell Inspiron 3520 Screen Replacement: step 9, image 2 of 2
    • Open the laptop and locate the two hinges.
    • Each hinge has two 5mm Phillips #00 screws that need to be removed.
    • With the screws removed the screen should pull free.
5 other people completed this guide.
Ian
1,557 Reputation
5 Guides authored
USF Tampa, Team 16-2, Watkins Winter 2015 Member of USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Members
5 Guides authored
One Comment
These instructions are not for screen replacement
Ryan Zulu - Reply
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 46
All Time: 5,812
