Dell Inspiron 5100 PP07L Memory Replacement
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: step 1, image 1 of 1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: step 2, image 1 of 1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 1 of 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 2 of 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: step 3, image 3 of 3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
2 other people completed this guide.
May Chauvin
201 Reputation
6 Guides authored
Cal Poly, Team 12-34, Maness Spring 2011 Member of Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 4,519
