Dell Inspiron 5100 PP07L Screen Replacement
  1. Dell Inspiron 5100 PP07L Screen Replacement, Keyboard: step 1, image 1 of 1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L Screen Replacement: step 2, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 2, image 2 of 2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L Screen Replacement: step 3, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 3, image 2 of 2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L Screen Replacement: step 4, image 1 of 1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L Screen Replacement, Screen: step 5, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement, Screen: step 5, image 2 of 2
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Dell Inspiron 5100 PP07L Screen Replacement: step 6, image 1 of 1
    • Detach the screen connector.
  7. Dell Inspiron 5100 PP07L Screen Replacement: step 7, image 1 of 2 Dell Inspiron 5100 PP07L Screen Replacement: step 7, image 2 of 2
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Dell Inspiron 5100 PP07L Screen Replacement: step 8, image 1 of 1
    • Lift and remove display screen.
May Chauvin
201 Reputation
6 Guides authored
Cal Poly, Team 12-34, Maness Spring 2011 Member of Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,679
