Dell Inspiron 5570 Battery Replacement
  1. Dell Inspiron 5570 Battery Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell Inspiron 5570 Battery Replacement, Unfasten the back cover: step 1, image 2 of 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 5570 Battery Replacement, Unclip the front corners: step 2, image 1 of 2 Dell Inspiron 5570 Battery Replacement, Unclip the front corners: step 2, image 2 of 2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 5570 Battery Replacement, Unclip the front edge: step 3, image 1 of 2 Dell Inspiron 5570 Battery Replacement, Unclip the front edge: step 3, image 2 of 2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 5570 Battery Replacement, Remove the back cover: step 4, image 1 of 3 Dell Inspiron 5570 Battery Replacement, Remove the back cover: step 4, image 2 of 3 Dell Inspiron 5570 Battery Replacement, Remove the back cover: step 4, image 3 of 3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 5570 Battery Replacement, Disconnect the battery: step 5, image 1 of 2 Dell Inspiron 5570 Battery Replacement, Disconnect the battery: step 5, image 2 of 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 5570 Battery Replacement, Unfasten the battery: step 6, image 1 of 2 Dell Inspiron 5570 Battery Replacement, Unfasten the battery: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the four 4 mm-long screws securing the battery.
  7. Dell Inspiron 5570 Battery Replacement, Remove the battery: step 7, image 1 of 3 Dell Inspiron 5570 Battery Replacement, Remove the battery: step 7, image 2 of 3 Dell Inspiron 5570 Battery Replacement, Remove the battery: step 7, image 3 of 3
    • Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
3 other people completed this guide.
Alex Diaz-Kokaisl
162,044 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,420 Guides authored
2 Comments
These instructions did not match my laptop, since they did not cover the removal of the DVD drive and removing two screws underneath where the drive goes. Also, there seems to be a difference in the location of some of the screws on my laptop. Maybe Dell changed the Inspiron 5570 and there are different flavors of it. I found the video here to be helpful in figuring out how to proceed: https://www.youtube.com/watch?v=IhTu834o...
Regarding steps 5 and 6, I had to remove the battery (#6) to access the tab (#5) because it was underneath the battery.
I highly recommend the screwdriver and picks.
GreyBeardOne - Reply
i had the same issues, and funny enough in every youtube video they talk about the hooks on the side of the battery connector, but there were no hooks on mine..
Ugo Saletti - Reply
Past 24 Hours: 7
Past 7 Days: 84
Past 30 Days: 298
All Time: 6,137
