Dell Inspiron 6000 DVD/CD Drive Replacement
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: step 2, image 1 of 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: step 3, image 1 of 1
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: step 4, image 1 of 1
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: step 5, image 1 of 1
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: step 6, image 1 of 1
    • Using your hand, pull the disk drive out of the laptop.
Kenneth Odum
545 Reputation
4 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 23
All Time: 1,896
