Dell Inspiron 6000 Keyboard Replacement
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: step 2, image 1 of 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 1 of 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 2 of 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: step 4, image 1 of 2 Dell Inspiron 6000 Keyboard Replacement: step 4, image 2 of 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: step 5, image 1 of 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: step 6, image 1 of 3 Dell Inspiron 6000 Keyboard Replacement: step 6, image 2 of 3 Dell Inspiron 6000 Keyboard Replacement: step 6, image 3 of 3
    • Gently pull the blue tab up until it comes away from computer.
5 other people completed this guide.
Jacob DeWar
548 Reputation
3 Guides authored
USF Tampa, Team 11-1, Blackwell Fall 2014 Member of USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Members
7 Guides authored
1 Guide Comment
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,332
