Dell Inspiron 600m Hard Drive Replacement
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: step 2, image 1 of 1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: step 3, image 1 of 1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: step 4, image 1 of 1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
7 other people completed this guide.
Todd
146 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
8 Guides authored
2 Comments
What size is the hard drive, you know, to buy a new one?
Ethan White - Reply
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 41
All Time: 17,320
