Dell Inspiron 600m Keyboard Replacement
  1. Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m Keyboard Replacement, Battery: step 1, image 3 of 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Orient laptop with the keyboard facing upward and the lid open.
  3. Dell Inspiron 600m Keyboard Replacement: step 3, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 3, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 3, image 3 of 3
    • Caution the face plate is a fragile piece of plastic. Handle carefully.
    • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
    • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
    • Carefully lift the screwdriver to remove the face plate.
  4. Dell Inspiron 600m Keyboard Replacement: step 4, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 4, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 4, image 3 of 3
    • Use a the Phillips screwdriver to remove the two screws.
  5. Dell Inspiron 600m Keyboard Replacement: step 5, image 1 of 1
    • Gently slide keyboard toward screen.
    • Lift keyboard carefully. It is attached by a ribbon cable.
  6. Dell Inspiron 600m Keyboard Replacement: step 6, image 1 of 3 Dell Inspiron 600m Keyboard Replacement: step 6, image 2 of 3 Dell Inspiron 600m Keyboard Replacement: step 6, image 3 of 3
    • Pull upward on blue tab to disconnect keyboard.
3 other people completed this guide.
Peter Hallsten
148 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 10
All Time: 3,502
