Dell Inspiron 600m LCD Replacement
  1. Dell Inspiron 600m LCD Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 600m LCD Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 600m LCD Replacement, Battery: step 1, image 3 of 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m LCD Replacement, LCD: step 2, image 1 of 2 Dell Inspiron 600m LCD Replacement, LCD: step 2, image 2 of 2
    • Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
    • Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
  3. Dell Inspiron 600m LCD Replacement: step 3, image 1 of 2 Dell Inspiron 600m LCD Replacement: step 3, image 2 of 2
    • Use the IFixit Opening Tool to un-clip the plastic cover, detaching it from the rest of the screen.
    • There are clips about every inch around the right, left, and top of the plastic cover. Be sure that all of them are unclipped.
  4. Dell Inspiron 600m LCD Replacement: step 4, image 1 of 1
    • Pull straight up on the cover to lift the cover off of the rest of the screen.
    • The bottom part of the plastic is a little sticky.
  5. Dell Inspiron 600m LCD Replacement: step 5, image 1 of 1
    • Remove four screws (two on each side of the screen) with the Phillips #00 screwdriver.
    • The middle screw does not need to be removed.
  6. Dell Inspiron 600m LCD Replacement: step 6, image 1 of 1
    • Gently lift the LCD panel off of the base.
    • The LCD is still attached to the computer. Do not pull too hard or you could break the cable.
  7. Dell Inspiron 600m LCD Replacement: step 7, image 1 of 3 Dell Inspiron 600m LCD Replacement: step 7, image 2 of 3 Dell Inspiron 600m LCD Replacement: step 7, image 3 of 3
    • Flip the LCD panel over.
    • Do not touch on or near the back of the panel where it says "Don't Touch." LCD panels contain mercury which is hazardous to humans.
    • Remove the cable by squeezing each side of the connector and gently pulling straight out.
  8. Dell Inspiron 600m LCD Replacement: step 8, image 1 of 3 Dell Inspiron 600m LCD Replacement: step 8, image 2 of 3 Dell Inspiron 600m LCD Replacement: step 8, image 3 of 3
    • Remove the cable at the base of the laptop by pulling up on the yellow tab attached to the cable.
4 other people completed this guide.
Alex Klimaj
143 Reputation
1 Guide authored
Cal Poly, Team 10-40, Forte Spring 2011 Member of Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 19
All Time: 6,923
