Dell Inspiron 7000 2 in 1 Battery Replacement
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: step 1, image 1 of 1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: step 2, image 1 of 1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 7000 2 in 1 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 7000 2 in 1 Battery Replacement: step 3, image 3 of 3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: step 4, image 1 of 1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: step 5, image 1 of 1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: step 6, image 1 of 1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: step 7, image 1 of 1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: step 8, image 1 of 1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: step 9, image 1 of 1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: step 10, image 1 of 1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Finish Line
3 other people completed this guide.
Neelay Patel
255 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 36
Past 30 Days: 176
All Time: 6,008
