Dell Inspiron 700m  Hinge Cover  Replacement
irlanda
irlanda and 4 other contributors
Last updated on July 26, 2024
No estimate
Easy
Community-Contributed Guide
Better Introduction
Missing Details
Tools
  • Spudger
    Spudger
  1. Dell Inspiron 700m  Hinge Cover  Replacement, Removing battery: step 1, image 1 of 1
    • Remove the battery by sliding and holding the battery release latch.
    • Make sure your computer is turned off and unplugged.
  2. Dell Inspiron 700m  Hinge Cover  Replacement, Open display: step 2, image 1 of 1
    • Open the display 180 degrees.
  3. Dell Inspiron 700m  Hinge Cover  Replacement, Removing Display: step 3, image 1 of 1
    • Use a plastic flat screwdriver to slide the hinge caps away from the computer.
    • Detach the two display latches on the back of the computer.
    • Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
    • Carefully, lift the hinge cover from the main unit and remove it from the main unit.
irlanda
11,528 Reputation
2 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 179
