Dell Inspiron 7306 P125 Battery Replacement
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7306 P125 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: step 2, image 1 of 2 Dell Inspiron 7306 P125 Battery Replacement: step 2, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 3, image 3 of 3
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 7306 P125 Battery Replacement: step 4, image 2 of 2
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: step 5, image 1 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 5, image 2 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 5, image 3 of 3
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: step 6, image 1 of 2 Dell Inspiron 7306 P125 Battery Replacement: step 6, image 2 of 2
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: step 7, image 1 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 7, image 2 of 3 Dell Inspiron 7306 P125 Battery Replacement: step 7, image 3 of 3
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
Arturo Gonzalez
172 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 60
All Time: 697
