Dell Inspiron 7486 Chromebook Battery Replacement
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7486 Chromebook Battery Replacement, Battery: step 1, image 2 of 2
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: step 2, image 1 of 2 Dell Inspiron 7486 Chromebook Battery Replacement: step 2, image 2 of 2
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: step 3, image 1 of 2 Dell Inspiron 7486 Chromebook Battery Replacement: step 3, image 2 of 2
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: step 4, image 1 of 3 Dell Inspiron 7486 Chromebook Battery Replacement: step 4, image 2 of 3 Dell Inspiron 7486 Chromebook Battery Replacement: step 4, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: step 5, image 1 of 2 Dell Inspiron 7486 Chromebook Battery Replacement: step 5, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: step 6, image 1 of 3 Dell Inspiron 7486 Chromebook Battery Replacement: step 6, image 2 of 3 Dell Inspiron 7486 Chromebook Battery Replacement: step 6, image 3 of 3
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
4 other people completed this guide.
[deleted]
265 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 61
All Time: 846
