Dell Inspiron 7568 Cooling Fan Replacement Guide
  1. Dell Inspiron 7568 Cooling Fan Replacement Guide, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Cooling Fan Replacement Guide, Battery: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Cooling Fan Replacement Guide: step 2, image 1 of 2 Dell Inspiron 7568 Cooling Fan Replacement Guide: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Cooling Fan Replacement Guide, Cooling Fan: step 3, image 1 of 2 Dell Inspiron 7568 Cooling Fan Replacement Guide, Cooling Fan: step 3, image 2 of 2
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  4. Dell Inspiron 7568 Cooling Fan Replacement Guide: step 4, image 1 of 2 Dell Inspiron 7568 Cooling Fan Replacement Guide: step 4, image 2 of 2
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
3 other people completed this guide.
Yash Samant
394 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Lacy Spring 2017 Member of USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 588
