Dell Inspiron 7568 Display Assembly Replacement Guide
  1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Display Assembly Replacement Guide: step 2, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: step 3, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: step 3, image 2 of 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Dell Inspiron 7568 Display Assembly Replacement Guide: step 4, image 1 of 2 Dell Inspiron 7568 Display Assembly Replacement Guide: step 4, image 2 of 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 1 of 3 Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 2 of 3 Dell Inspiron 7568 Display Assembly Replacement Guide: step 5, image 3 of 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Dell Inspiron 7568 Display Assembly Replacement Guide: step 6, image 1 of 1
    • Carefully separate the screen from the bottom half of the device.
2 other people completed this guide.
Yash Samant
406 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Lacy Spring 2017 Member of USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,171
