Dell Inspiron 7568 Hard-Drive Replacement
  1. Dell Inspiron 7568 Hard-Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Hard-Drive Replacement, Battery: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Hard-Drive Replacement: step 2, image 1 of 2 Dell Inspiron 7568 Hard-Drive Replacement: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Hard-Drive Replacement, Hard-Drive: step 3, image 1 of 1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Hard-Drive Replacement: step 4, image 1 of 2 Dell Inspiron 7568 Hard-Drive Replacement: step 4, image 2 of 2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Hard-Drive Replacement: step 5, image 1 of 1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Hard-Drive Replacement: step 6, image 1 of 1
    • Remove the hard drive (right) from its frame (left).
Elijah Basile
358 Reputation
4 Guides authored
IUPUI, Team S1-G4, Stella Fall 2019 Member of IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Members
4 Guides authored
One Comment
Will a 9mm 2.5” SSD fit in these? or can it be forced in? p16 of the spec sheet says “7mm” but I’m not sure if that’s just saying stock configuration just comes with a 7mm drive? or that it only supports up to 7mm?: https://dl.dell.com/manuals/all-products... Any clarification appreciated, thanks!
Blacknova - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 379
