Dell Inspiron 7568 Motherboard Replacement
  1. Dell Inspiron 7568 Motherboard Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Motherboard Replacement: step 2, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Motherboard Replacement, RAM: step 3, image 1 of 1
    • Release the RAM by unhinging the connecting bars outward.
  4. Dell Inspiron 7568 Motherboard Replacement: step 4, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 4, image 2 of 2
    • Remove the RAM.
  5. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: step 5, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: step 5, image 2 of 2
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  6. Dell Inspiron 7568 Motherboard Replacement: step 6, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement: step 6, image 2 of 2
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  7. Dell Inspiron 7568 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Dell Inspiron 7568 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove six 3mm Phillips #1 screws to fully remove the motherboard.
    • Disconnect the various connection points from the motherboard to the laptop.
    • Remove the motherboard.
Elijah Basile
358 Reputation
4 Guides authored
IUPUI, Team S1-G4, Stella Fall 2019 Member of IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 296
