Dell Inspiron 7568 Wifi Card Replacement
  1. Dell Inspiron 7568 Wifi Card Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement, Battery: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Wifi Card Replacement: step 2, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement: step 2, image 2 of 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Wifi Card Replacement, Hard-Drive: step 3, image 1 of 1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Wifi Card Replacement: step 4, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement: step 4, image 2 of 2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Wifi Card Replacement: step 5, image 1 of 1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Wifi Card Replacement: step 6, image 1 of 1
    • Remove the hard drive (right) from its frame (left).
  7. Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: step 7, image 1 of 2 Dell Inspiron 7568 Wifi Card Replacement, Wifi Card: step 7, image 2 of 2
    • Remove the wide-brimmed 3mm Phillips #1 screw connecting the Wifi Card.
    • Remove the Wifi Card.
Elijah Basile
358 Reputation
4 Guides authored
IUPUI, Team S1-G4, Stella Fall 2019 Member of IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 164
