Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement
  1. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Battery: step 1, image 2 of 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 2, image 1 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 2, image 2 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 2, image 3 of 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 4, image 1 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 4, image 2 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: step 4, image 3 of 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 1 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 2 of 3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: step 5, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the 3 mm screw that secures the wireless-card bracket and wireless card to the I/O board.
    • Lift the wireless-card bracket off of the wireless card.
    • Disconnect the white and black antenna cables from the wireless card.
    • Slide and remove the wireless card from the wireless card slot.
Austin Blakely
19,961 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,085 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 320
