Dell Inspiron 7590 Battery Replacement
  1. Dell Inspiron 7590 Battery Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 7590 Battery Replacement, Battery: step 1, image 2 of 2
    • Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
    • Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
  2. Dell Inspiron 7590 Battery Replacement: step 2, image 1 of 3 Dell Inspiron 7590 Battery Replacement: step 2, image 2 of 3 Dell Inspiron 7590 Battery Replacement: step 2, image 3 of 3
    • Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
    • Separate the remainder of the paneling using an Opening Pick.
    • Avoid using a metal utensil when separating the remainder of the paneling to avoid paint chipping.
  3. Dell Inspiron 7590 Battery Replacement: step 3, image 1 of 3 Dell Inspiron 7590 Battery Replacement: step 3, image 2 of 3 Dell Inspiron 7590 Battery Replacement: step 3, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the three screws securing the battery.
  4. Dell Inspiron 7590 Battery Replacement: step 4, image 1 of 2 Dell Inspiron 7590 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, disconnect the ribbon cable connecting the battery to the motherboard.
  5. Dell Inspiron 7590 Battery Replacement: step 5, image 1 of 2 Dell Inspiron 7590 Battery Replacement: step 5, image 2 of 2
    • Remove the battery from the device.
2 other people completed this guide.
One Comment
Hello,
I noticed in your tear down there are two ram slots. I tried to find this information online, but was unable to. Are any of those ram slots an empty slot, to possibly upgrade?
Dave Szes - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 19
All Time: 1,525
