Dell Inspiron 8600 Power Button Replacement
  1. Dell Inspiron 8600 Power Button Replacement, Battery: step 1, image 1 of 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 1 of 3 Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 2 of 3 Dell Inspiron 8600 Power Button Replacement, Power Button: step 2, image 3 of 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Power Button Replacement: step 3, image 1 of 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
3 other people completed this guide.
Brian Murphy
368 Reputation
4 Guides authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 16
All Time: 4,165
