Dell Inspiron 8600 Upper Case Replacement
  1. Dell Inspiron 8600 Upper Case Replacement, Battery: step 1, image 1 of 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: step 2, image 1 of 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: step 2, image 2 of 3 Dell Inspiron 8600 Upper Case Replacement, Hinge Cover: step 2, image 3 of 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Upper Case Replacement: step 3, image 1 of 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Upper Case Replacement, Keyboard: step 4, image 1 of 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: step 4, image 2 of 3 Dell Inspiron 8600 Upper Case Replacement, Keyboard: step 4, image 3 of 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Upper Case Replacement, Display Module: step 5, image 1 of 2 Dell Inspiron 8600 Upper Case Replacement, Display Module: step 5, image 2 of 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Upper Case Replacement: step 6, image 1 of 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Upper Case Replacement: step 7, image 1 of 2 Dell Inspiron 8600 Upper Case Replacement: step 7, image 2 of 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Upper Case Replacement: step 8, image 1 of 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Upper Case Replacement, Upper Case: step 9, image 1 of 2 Dell Inspiron 8600 Upper Case Replacement, Upper Case: step 9, image 2 of 2
    • Remove the two screws that hold the upper case.
    • You can now pop up the upper case and replace.
John Nesthus
186 Reputation
6 Guides authored
Cal Poly, Team 18-22, Garner Spring 2011 Member of Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 2,618
