Dell Inspiron 9100 Keyboard Replacement
  1. Dell Inspiron 9100 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Keyboard Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Keyboard Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Keyboard Replacement: step 2, image 3 of 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Keyboard Replacement, Keyboard: step 3, image 1 of 1
    • Turn the laptop around.
  4. Dell Inspiron 9100 Keyboard Replacement: step 4, image 1 of 3 Dell Inspiron 9100 Keyboard Replacement: step 4, image 2 of 3 Dell Inspiron 9100 Keyboard Replacement: step 4, image 3 of 3
    • Use your fingers to gently pull up on the hinge covers. They will release with an audible snap.
    • Fold the screen back to 180 degrees.
    • Using your index fingers, pull up the hinge cover.
  5. Dell Inspiron 9100 Keyboard Replacement: step 5, image 1 of 3 Dell Inspiron 9100 Keyboard Replacement: step 5, image 2 of 3 Dell Inspiron 9100 Keyboard Replacement: step 5, image 3 of 3
    • After the hinges pop, pull the hinge cover gently.
    • Pull the clear tab on the right side of the laptop up. This tab will disconnect the hinge cover from the laptop.
  6. Dell Inspiron 9100 Keyboard Replacement: step 6, image 1 of 1
    • Remove the two 3mm screws on the top of the keyboard (nearest to the screen)
  7. Dell Inspiron 9100 Keyboard Replacement: step 7, image 1 of 3 Dell Inspiron 9100 Keyboard Replacement: step 7, image 2 of 3 Dell Inspiron 9100 Keyboard Replacement: step 7, image 3 of 3
    • Tilt the keyboard away from the screen.
    • Pull up on the white tab underneath the keyboard to release the keyboard.
Ana
111 Reputation
1 Guide authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,976
