Dell Inspiron 9100 Optical Drive/Accessory Device Replacement
  1. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Battery: step 1, image 3 of 3
    • Unplug the laptop from the power adapter and turn the power off.
    • Failure to unplug laptop before proceeding could result in risk of electric shock!
  2. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement: step 2, image 3 of 3
    • Slide the battery-lock tab and hold.
    • Flip the battery away from the chassis to remove it.
  3. Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 1 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 2 of 3 Dell Inspiron 9100 Optical Drive/Accessory Device Replacement, Optical Drive/Accessory Device: step 3, image 3 of 3
    • Press the tab on the outside face of the optical drive to release a handle.
    • Pull the handle to eject the optical drive unit from the slot, and slide it out.
charlierefvem
854 Reputation
7 Guides authored
Cal Poly, Team 13-2, Forte Winter 2011 Member of Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 2,323
