Dell Inspiron 9300 Modem Replacement
  1. Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: step 1, image 1 of 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: step 1, image 2 of 3 Dell Inspiron 9300 Modem Replacement, Modem & WIFI Card Prerequisite: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 Modem Replacement: step 2, image 1 of 2 Dell Inspiron 9300 Modem Replacement: step 2, image 2 of 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 Modem Replacement, Modem Card: step 3, image 1 of 2 Dell Inspiron 9300 Modem Replacement, Modem Card: step 3, image 2 of 2
    • Remove the screw holding the card in place using a size #0 Phillips screwdriver.
    • Gently unplug the card from the connecting black wire using a black spudger.
    • The modem can now be safely removed.
Randy McMillan
738 Reputation
4 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,473 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 31
All Time: 339
