Dell Inspiron 9300 RAM Replacement
  1. Dell Inspiron 9300 RAM Replacement, RAM: step 1, image 1 of 2 Dell Inspiron 9300 RAM Replacement, RAM: step 1, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a #0 Phillips screw driver.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
    • The screws are secured by retainer clips in the plastic panel and are not fully removable.
  2. Dell Inspiron 9300 RAM Replacement: step 2, image 1 of 1
    • Remove the plastic panel.
  3. Dell Inspiron 9300 RAM Replacement: step 3, image 1 of 2 Dell Inspiron 9300 RAM Replacement: step 3, image 2 of 2
    Heavy-Duty Spudger
    Buy
    • Carefully pry away the retaining clips on either side of the ram modules using a spudger tool, until the card pops away from the motherboard.
    • Repeat for the second ram module if necessary.
  4. Dell Inspiron 9300 RAM Replacement: step 4, image 1 of 1
    • Carefully pull the ram modules out of it's slot, away from the motherboard.
Randy McMillan
738 Reputation
4 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,473 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 515
