Dell Inspiron E1405 Heat Sink Replacement
  1. Dell Inspiron E1405 Heat Sink Replacement, Battery: step 1, image 1 of 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 Heat Sink Replacement: step 2, image 1 of 3 Dell Inspiron E1405 Heat Sink Replacement: step 2, image 2 of 3 Dell Inspiron E1405 Heat Sink Replacement: step 2, image 3 of 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: step 3, image 1 of 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: step 3, image 2 of 3 Dell Inspiron E1405 Heat Sink Replacement, Heat Sink: step 3, image 3 of 3
    • Remove/loosen the eight 4.8mm screws with a #1 Phillips screwdriver securing the bottom panel.
    • Remove the bottom panel.
  4. Dell Inspiron E1405 Heat Sink Replacement: step 4, image 1 of 3 Dell Inspiron E1405 Heat Sink Replacement: step 4, image 2 of 3 Dell Inspiron E1405 Heat Sink Replacement: step 4, image 3 of 3
    • Loosen the five 5.5mm screws with a #1 Phillips screwdriver securing the heat sink and clean it with compressed air
    • Gently lift the heat sink from the side, as indicated in the picture.
Sarah Neal Secrest
597 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 237
