Dell Inspiron E1405 LCD Screen Replacement
  1. Dell Inspiron E1405 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Save your work, power the laptop off, and ensure that the charging cable is unplugged before removing the battery.
    • Flip the laptop over.
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron E1405 LCD Screen Replacement: step 2, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 2, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 2, image 3 of 3
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement, LCD Screen: step 3, image 3 of 3
    • Use your fingers or a spudger to remove the six small rubber covers off the display assembly.
    • Remove the six 5.7 mm screws with a Phillips #00 screwdriver.
  4. Dell Inspiron E1405 LCD Screen Replacement: step 4, image 1 of 1
    • Use your fingers to gently pry the front bezel off the display assembly. Start at a corner and work your way around.
    • Remove the front display bezel when it comes free.
  5. Dell Inspiron E1405 LCD Screen Replacement: step 5, image 1 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 5, image 2 of 3 Dell Inspiron E1405 LCD Screen Replacement: step 5, image 3 of 3
    • Remove the three 3.6 mm screws using a Phillips #00 screwdriver on both sides of the display.
    • Remove the LCD screen from the display assembly.
  6. Dell Inspiron E1405 LCD Screen Replacement: step 6, image 1 of 2 Dell Inspiron E1405 LCD Screen Replacement: step 6, image 2 of 2
    • Unplug the VGA cable by pushing the two metal sides towards the middle of the strip.
    • Gently pull the VGA cable away to release the strip.
  7. Dell Inspiron E1405 LCD Screen Replacement: step 7, image 1 of 2 Dell Inspiron E1405 LCD Screen Replacement: step 7, image 2 of 2
    • Remove the next connection by pressing the two metal sides towards the middle. Then gently pull up the ribbon.
Sarah Neal Secrest
597 Reputation
5 Guides authored
One Comment
I need complete body *Dell INSPIRON E1405 .
St Master Fun - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 471
