Dell Inspiron E1505 GPU Replacement
  1. Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: step 1, image 1 of 3 Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: step 1, image 2 of 3 Dell Inspiron E1505 GPU Replacement, Battery and Optical drive: step 1, image 3 of 3
    • Slide the battery disconnect right.
    • Remove the screw for the optical drive.
    • Use a screwdriver to push the optical drive out of the base.
    • Gently pull the drive out when it sticks out far enough.
  2. Dell Inspiron E1505 GPU Replacement, Base Screws: step 2, image 1 of 2 Dell Inspiron E1505 GPU Replacement, Base Screws: step 2, image 2 of 2
    • Unscrew all 12 screws on the base of the laptop
    • Remove the 2 screws at the back of the laptop.
  3. Dell Inspiron E1505 GPU Replacement, Power Button panel.: step 3, image 1 of 3 Dell Inspiron E1505 GPU Replacement, Power Button panel.: step 3, image 2 of 3 Dell Inspiron E1505 GPU Replacement, Power Button panel.: step 3, image 3 of 3
    • Rotate the screen to a 180-degree position.
    • Take a flat head screwdriver and gently pry at the indentation. It should come open semi-easily.
    • Grab the panel and gently pull it off
  4. Dell Inspiron E1505 GPU Replacement, Keyboard and display: step 4, image 1 of 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: step 4, image 2 of 3 Dell Inspiron E1505 GPU Replacement, Keyboard and display: step 4, image 3 of 3
    • Remove the two screws and slide the keyboard toward the display.
    • There is a delicate ribbon cable attached to the bottom of the keyboard. Be careful when removing it.
    • Rotate the latch up toward the trackpad, then carefully remove the ribbon cable.
    • Remove the antenna connectors on the wifi card by pulling up at the part where the cable meets the connector.
    • Unscrew the grounding cable on the display cable. Disconnect the display cable by pulling up on the tab.
    • Remove the last two screws holding the display in. Rotate the display to an upright 90-degree position. Gently pull up to remove the display.
  5. Dell Inspiron E1505 GPU Replacement, Top Panel: step 5, image 1 of 3 Dell Inspiron E1505 GPU Replacement, Top Panel: step 5, image 2 of 3 Dell Inspiron E1505 GPU Replacement, Top Panel: step 5, image 3 of 3
    • Disconnect the ribbon cable from the motherboard
    • Disconnect the lid sensor.
    • Unscrew the last screw holding the top panel in.
    • Lift the panel.
    • There may be clips in the back, slide your finger to pry them off.
    • If you can't lift the panel, check if there are any screws on the base holding it.
  6. Dell Inspiron E1505 GPU Replacement, GPU: step 6, image 1 of 3 Dell Inspiron E1505 GPU Replacement, GPU: step 6, image 2 of 3 Dell Inspiron E1505 GPU Replacement, GPU: step 6, image 3 of 3
    • Remove the two screws shown.
    • Use a screwdriver to pry the GPU and cooler up.
    • Use a screwdriver with a larger diameter shank to disconnect the gpu.
    • To reconnect the gpu, align it and firmly press at the "Press here" label.
TMG
614 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 251
