Dell Inspiron E1705 Optical Drive Replacement
  1. Dell Inspiron E1705 Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Optical Drive Replacement: step 2, image 1 of 2 Dell Inspiron E1705 Optical Drive Replacement: step 2, image 2 of 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Dell Inspiron E1705 Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
    • Locate and remove the screw shown
    • It is labeled with a lock symbol
  4. Dell Inspiron E1705 Optical Drive Replacement: step 4, image 1 of 2 Dell Inspiron E1705 Optical Drive Replacement: step 4, image 2 of 2
    • Use the screwdriver to gently push the optical drive out
3 other people completed this guide.
Evan Fairchild
613 Reputation
4 Guides authored
Cal Poly, Team 22-5, Maness Fall 2010 Member of Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 12
All Time: 3,954
