Dell Inspiron M5010 Hard Drive Replacement
  1. Dell Inspiron M5010 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Inspiron M5010 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure laptop is powered off before removing the battery.
    • Slide both arrow tabs towards the outer edge of the computer to release the battery.
    • Battery is not shown.
  2. Dell Inspiron M5010 Hard Drive Replacement, Remove keyboard retaining screw: step 2, image 1 of 1
    • Remove Keyboard retaining screw from bottom of laptop.
  3. Dell Inspiron M5010 Hard Drive Replacement: step 3, image 1 of 3 Dell Inspiron M5010 Hard Drive Replacement: step 3, image 2 of 3 Dell Inspiron M5010 Hard Drive Replacement: step 3, image 3 of 3
    • Insert the 6 inch metal ruler, or another flat object into the holes in the top left of the keyboard, the top middle of the keyboard, and the top right of the keyboard to release the keyboard from the computer.
    • There are a number of screws on the bottom that required to be removed prior to the keyboard being able to be lifted up.
  4. Dell Inspiron M5010 Hard Drive Replacement: step 4, image 1 of 1
    • Lift the keyboard up slightly and push forward in order to release bottom tabs.
  5. Dell Inspiron M5010 Hard Drive Replacement: step 5, image 1 of 1
    • Pull the black tab up and then pull left on keyboard plug to release keyboard.
  6. Dell Inspiron M5010 Hard Drive Replacement, Palm Rest: step 6, image 1 of 1
    • Flip the laptop, so the bottom of the laptop is facing up.
    • Remove the seven 6.0mm Phillip #000 screws indicated using the Phillips #000 screwdriver.
  7. Dell Inspiron M5010 Hard Drive Replacement: step 7, image 1 of 2 Dell Inspiron M5010 Hard Drive Replacement: step 7, image 2 of 2
    • Flip the laptop back over, so that the top of the laptop is facing up.
    • Open the laptop.
    • Remove all of the indicated 6.0 mm screws with the Phillips #000 screwdriver.
  8. Dell Inspiron M5010 Hard Drive Replacement: step 8, image 1 of 1
    • Unplug the palm rest cables by lifting the black tab up and then pulling on the blue tabs.
  9. Dell Inspiron M5010 Hard Drive Replacement: step 9, image 1 of 3 Dell Inspiron M5010 Hard Drive Replacement: step 9, image 2 of 3 Dell Inspiron M5010 Hard Drive Replacement: step 9, image 3 of 3
    • Carefully unsnap and remove the palm rest.
    • Place your fingers inside the large circle in the lower right corner to get a good grip.
  10. Dell Inspiron M5010 Hard Drive Replacement, Hard Drive: step 10, image 1 of 1
    • Remove the 4 mm Hard Drive screws with the Phillips #000 screwdriver.
  11. Dell Inspiron M5010 Hard Drive Replacement: step 11, image 1 of 2 Dell Inspiron M5010 Hard Drive Replacement: step 11, image 2 of 2
    • Flip laptop over.
    • Open lap top.
    • Pull the clear tab attached to the hard drive and gently lift up the hard drive.
12 other people completed this guide.
Sydney Moseley
452 Reputation
1 Guide authored
Clemson, Team 1-5, Benson Fall 2014 Member of Clemson, Team 1-5, Benson Fall 2014
CLEM-BENSON-F14S1G5
4 Members
11 Guides authored
One Comment
Thank you it was very helpful.
John Peel - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 9,462
