Dell Inspiron M511R Module Cover Replacement
  1. Dell Inspiron M511R Module Cover Replacement, REMOVE BATTERY: step 1, image 1 of 1
    • Insert wisdom here.
  2. Dell Inspiron M511R Module Cover Replacement, Removing the Module Cover: step 2, image 1 of 1
    • Loosen the captive screw that secures the module cover to the base cover
    • Using your fingertips, release the tabs on the module cover from the slots on the computer base
    • Lift the module cover off the computer base
  3. Dell Inspiron M511R Module Cover Replacement, removing memory module: step 3, image 1 of 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up
    • Remove the memory module from the memory-module connector.
  4. Dell Inspiron M511R Module Cover Replacement, Replacing the Memory Module: step 4, image 1 of 1
    • align the notch in the memory module with the tab in the memory-module connector.
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Replace the module cover
    • Replace the battery
Jordon Dozier
1,663 Reputation
12 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,985 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 23
