Introduction
This guide is to help you locate and replace the battery in your Dell Inspiron Mini 1012. Indications that help you identify whether or not you need to replace your battery include if your battery appears swollen, if your computer’s charge runs out unexpectedly or faster than normal, or if your computer overheats easily. If your battery appears swollen in any capacity or to check if your battery is swollen, please read this guide about swollen batteries. Before taking any steps, read this guide about power safety.
Turn the device over so the bottom is facing upwards.
Slide the two tabs beside the lock icons to the unlocked position.
Find the notch located in the center between the two tabs and lift up on the battery to remove it.
To reassemble, place the new battery in the three slots. Lock the battery back in place.
One Comment
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
