Dell Inspiron N4110 Fan Replacement
  1. Dell Inspiron N4110 Fan Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Fan Replacement: step 2, image 1 of 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Fan Replacement: step 3, image 1 of 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Fan Replacement, Fan: step 4, image 1 of 2 Dell Inspiron N4110 Fan Replacement, Fan: step 4, image 2 of 2
    • Remove the 10 2.5x5 mm screws from the base of the laptop.
  5. Dell Inspiron N4110 Fan Replacement: step 5, image 1 of 1
    • Unscrew the final 2.5x5 mm screw attached to the cover.
    • This screw is "captive" and does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  6. Dell Inspiron N4110 Fan Replacement: step 6, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 6, image 2 of 2
    • Remove the cover from the laptop.
  7. Dell Inspiron N4110 Fan Replacement: step 7, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 7, image 2 of 2
    • Unscrew the 2.5x5 mm screw inside the RAM compartment.
  8. Dell Inspiron N4110 Fan Replacement: step 8, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 8, image 2 of 2
    • Remove the disk drive from the side of the computer.
    • There is no need to press the button, the drive will come out.
  9. Dell Inspiron N4110 Fan Replacement: step 9, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 9, image 2 of 2
    • Unscrew the two 2x3 mm screws inside the disk drive compartment.
  10. Dell Inspiron N4110 Fan Replacement: step 10, image 1 of 3 Dell Inspiron N4110 Fan Replacement: step 10, image 2 of 3 Dell Inspiron N4110 Fan Replacement: step 10, image 3 of 3
    • Flip the computer over, and open the laptop.
    • Use a plastic opening tool to begin to remove the keyboard.
    • Use your hands to finish separating the keyboard from the laptop.
    • This can be a bit challenging, but it will come loose.
  11. Dell Inspiron N4110 Fan Replacement: step 11, image 1 of 1
    • Lift the black clip from the tan connection for the keyboard.
    • Pull the the connection away from the clip.
    • Move the keyboard away from the laptop.
    • With the keyboard removed, consider this opportunity to more freely clean it out with some compressed air.
  12. Dell Inspiron N4110 Fan Replacement: step 12, image 1 of 1
    • Lift the black clips from the tan connections for all 3 locations marked.
    • Remove the connections from the clips.
  13. Dell Inspiron N4110 Fan Replacement: step 13, image 1 of 1
    • Unscrew the five 2.5x5 mm screws.
  14. Dell Inspiron N4110 Fan Replacement: step 14, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 14, image 2 of 2
    • Use plastic opening tools to remove base cover.
    • Use your hands to fully remove cover from the base.
    • This may be difficult, but it is possible.
  15. Dell Inspiron N4110 Fan Replacement: step 15, image 1 of 1
    • Disconnect the two cables that connect the speaker and the fan.
    • These can just be pulled out, they do not have clips.
  16. Dell Inspiron N4110 Fan Replacement: step 16, image 1 of 1
    • Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
    • Unscrew the 2.5x5 mm screw from the fan.
  17. Dell Inspiron N4110 Fan Replacement: step 17, image 1 of 2 Dell Inspiron N4110 Fan Replacement: step 17, image 2 of 2
    • Pull up and remove the fan from the laptop.
5 other people completed this guide.
Olivia
794 Reputation
3 Guides authored
One Comment
Wow! What a great guide. Really made the job easier. Thanks!!!
swtilden - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,308
