Dell Inspiron N4110 RAM Replacement
  1. Dell Inspiron N4110 RAM Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: step 2, image 1 of 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: step 3, image 1 of 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: step 4, image 1 of 2 Dell Inspiron N4110 RAM Replacement, RAM: step 4, image 2 of 2
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: step 5, image 1 of 2 Dell Inspiron N4110 RAM Replacement: step 5, image 2 of 2
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: step 6, image 1 of 2 Dell Inspiron N4110 RAM Replacement: step 6, image 2 of 2
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: step 7, image 1 of 1
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
2 other people completed this guide.
Olivia
794 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 795
